Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1998 Gmc Yukon Parking ...
Auto Repair1996 Toyota Corolla Rea...
Auto Repair1995 Chevy Lumina Heater
Auto Repair2002 Dodge Neon Bogging...
Auto Repair2004 Toyota Camry Airbag
Auto Repair2004 Toyota Tacoma Cabi...
Auto Repair2000 Chevy Silverado Cl...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1996 Plymouth Breeze Dash gauges not working when car is st
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Oct 21, 2008 6:14 pm
By buck35indiana, Have Donated
Give Feedback | Votes: 0
Electrical problem
1996 Plymouth Breeze 4 cyl Front Wheel Drive Automatic 120000 miles
My daughters 96 Breeze is having electrical problems. The gas gauge,tach, odometers, & other gauges are not functioning when the car is actually running. BUT the gas gauge does operate when the key is turned just past the accesory position. When running,the odometer is showing a messege that looks like" NO BUS(or NO BU5?)
The local Auto Zone man believes that the ECM (ECU?) is not functioning properly & suggests that I replace it. Of course there is a no return policy on this part so if I buy it, & it doesn't solve the problem than I'm just SOL on the cost. Any suggestions? Thanks
Find a car repair manual for your Plymouth Breeze Repair Question.
Posted at Tue Oct 21, 2008 7:07 pm
By ImpalaSS, Moderator
Reputation: 153.3Reputation: 153.3Reputation: 153.3Reputation: 153.3Reputation: 153.3Reputation: 153.3Reputation: 153.3Reputation: 153.3 (153) Give Feedback | Votes: 7
Hello
There is a self test you can perform. I have attached that. Make sure you check the fuses it talks about first.
For a Diagnostic check you need the DRB scan tool.
DIAGNOSTIC PROCEDURE
In order to diagnose the instrument cluster function, a DRB scan tool and the proper Body Diagnostic Procedures are required. See: Body and Frame\Body Control Systems\Body Control Module\Testing and Inspection\Procedures
As a quick diagnosis, the cluster will perform a function check immediately after the ignition is switched to the RUN/START position. The electronic display, odometer and transmission range indicator and all warning lamps except:
• Cruise
• Fog lamps
• High beam
• Low fuel
• Turn signal will illuminate for a brief period.
If the cluster is not receiving CCD bus messages, the cluster will appear nonfunctional except for the continuously illuminated airbag indicator and NO BUS message displayed.
If the cluster is not receiving CCD bus messages, refer to the Powertrain Management/Computers and Control Systems/pre-diagnostic test described in proper Body Diagnostic Procedures or refer to the Instrument Panel, Gauges and Warning Indicators/Instrument Panel/Instrument Cluster Self-Diagnostic Test.
INSTRUMENT CLUSTER SELF-DIAGNOSTICS
Initiate instrument cluster self-diagnostic by depressing the odometer/trip reset button while turning the ignition key to the OFF/RUN/START position. This will cycle an electronic display segment check and illumination in sequence of all CCD bus activated cluster warning indicators. There are four Check (CHECK) functions:
1. CHECK 1, checks the gauges.
2. CHECK 2, checks the warning lamps.
3. CHECK 3, checks the odometer/trip meter.
4. CHECK 4, Transmission Range Indicator for the automatic transmission or the autostick transmission. If the diagnostic procedure determines that a replacement of an instrument cluster component is required, refer to the proper component removal procedure.
CHECK I
If all gauges fail to move, replace Cluster Printed Circuit (PC) Board.
If any gauge fails to move, replace the gauge assembly
If any gauge(s) is not in the proper position, replace Cluster Printed Circuit Board.
CHECK 2
If any lamp does not light, check lamp.
If lamp is not OK, replace lamp.
If lamp is OK, replace Cluster Printed Circuit Board.
CHECK 3
If any V/F segment does not light, replace Odometer/Transmission Range Indication.
CHECK 4
Hope this helps
Thank you for the donation.
Find a car repair manual for your car repair questions.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
