Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1996 Other Dodge Models V8 Two Wheel Drive Automatic 160000 miles
my interior light do not work--- and when i shut my truck off my raidio reset it shelf--it a 1996 dodge van 1500
I'm going to assume you checked the interior bulbs and the fuse. First, check if there is power to the light socket. If not, you will need to the remove the switch from the door frame. Check if there is power to the switch. If there is, replace the switch. If not, you will need to trace the power wire back until you find the problem.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
