Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2002 Honda Civic Shifte...
Auto Repair2001 Toyota Sienna Driv...
Auto Repair2001 Dodge Stratus
Auto Repair2006 Honda Civic
Auto Repair2004 Chrysler Sebring W...
Auto Repair1991 Chevy Cavalier Car...
Auto Repair2002 Honda Civic Altern...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1996 Oldsmobile (EightyEight)Car shakes a wobbles when stopp
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Sat Jun 21, 2008 2:49 am
By columbian, Likes cars!
Give Feedback | Votes: 0
Shakes or Wobbles problem
1996 Other Oldsmobile Models 6 cyl Front Wheel Drive Automatic 70K miles
I heard a noise (very small explosion) yesterday afternoon when I started my car and since then it Shakes and Wobbles when car is stopped and is in Drive or Reverse gear. Couple weeks ago I had got a code from Autozone and it PO401 for EGR, I was going to get i fix this weekend and yesterday this shaking and wobbling began. Any suggestions? Your help is really appreciated.
Find a car repair manual for your Other Oldsmobile Models.
By Advertisment,
Posted at Sat Jun 21, 2008 3:24 am
By merlin2021, Certified 2CarPros Master Technician
Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3Reputation: 628.3 (628) Give Feedback | Votes: 50
P0401=EGR insufficient flow, remove the EGR and clear out the port it's blocked with carbon, I use a piece of steel coathanger, the backfire, may have ruined the idle air clontrol valve, it's bolted to the throttlebody with 2 screws...replace that.
Posted at Sat Jun 21, 2008 3:31 am
Thank you for quick response. Please note it was not shaking and wobbling when I got the code couple weeks back. It started yesterday. Is this still the problem witm with EGR?
Would you please let me know, How much would it cost if I take it to mechanic? Just to get an idea for this fix... Appreciate your help
Posted at Sat Jun 21, 2008 6:04 am
I checked new codes and those are PO108,PO171,PO300
My mechan is on vacation so checked with other mechanic. He told me I have to change fuel hose and gaskets, Is this diagnostic correct? What should be done to fix this. Please elt me know... appreciate your help on this...
Posted at Sun Jun 22, 2008 3:37 am
P0108= MAP/Baro circuit high input
P0171= System too lean bank 1
P0300=Random, multiple cylinder misfire detected.
All can be caused by fuel deliver problems, I don't see an EGR related code here? Can also be due to vacuum leaks!
You may have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs! If that doesnt do it, you may need a new idle air control valve, it's bolted to the throttlebody
Posted at Mon Jun 23, 2008 1:33 am
Thank you for your response... would it be due to damaged spark plug wires? As I had heard a small explosive noise before it started shaking and wobbling... Your opinion is appreciated... What is gumout spray??? I will also try checking the leak and will let you know the results...
Posted at Mon Jun 23, 2008 12:08 pm
Misfires, which you heard as the explosion, can be bad tune up parts, including plugs, wires, and coils.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
