Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1999 Buick Regal Stallin...
Auto Repair1995 Other Oldsmobile Mod...
Auto Repair2001 Hyundai Elantra His...
Auto Repair1997 Dodge Caravan Brake...
Auto Repair2002 Saturn Vue Intermit...
Auto Repair1997 Honda Accord Car Wo...
Auto Repair1996 Dodge Caravan 96 Ca...
Auto Repair1989 Ford Mustang Engine...
Auto Repair2000 Other Oldsmobile Mod...
Auto Repair1995 Honda Odyssey Car W...
Auto Repair1994 Buick Regal Ignitio...
Auto Repair1992 Honda Accord Engine...
Auto Repair1994 Ford F250 Blinkers
Auto Repair1999 Ford Contour Fan On...
Auto Repair1998 Chevy Silverado Cha...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1996 Nissan Sentra car wont start
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Mon May 12, 2008 7:32 am
By Zoey, New to the forum
Give Feedback | Votes: 0
Electrical problem
1996 Nissan Sentra 4 cyl Front Wheel Drive Automatic
silence when key is turned.key can turn which rules out ignition.Car can go into gear which would rule out neutral switch.Dont have a volt meter.How would I check starter without a volt meter.Cannot reach it from hood jacked car up and still cant reach starter.From under the hood can hear clicking when key is turned.
Find a repair manual for your Nissan Sentra Repair Question.
By Advertisment,
Posted at Tue May 20, 2008 12:27 pm
By frogr82, New to the forum
if any of your dashboard lights come on when turning the key your voltage should be fine. there are several causes for you situation. the starter, distibutor, injectors/carborator, and spark plugs. all of those will give the same problem. i have just replaced all of those in my sentra. check all those first. the starter will normally give a sign its bad as well as spark plugs and injectors. the starter will start then die when givin gas and spark and injectors will normally start to missfire when the go bad. check your sparks then distributor then go from there. you can find pictures of what your sparks should look like in a hanes book. or take one in and ask a person a autozone if it looks bad. hopes that helps
Posted at Tue Jun 24, 2008 9:55 am
By jalopypapa, Tech level 1
If this is the 1600 cc engine, yes, the starter can only be reached by one hand at a time from under the car, which makes it pretty hard to test safely in situ ... absent a proper tester/analyzer. So... I'd start by making sure the battery is fully charged and connections clean and tight. If you can get the car somehow to an auto parts store that does electrical system testing for free, they can tell you whether the starter is bad.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
