Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
1996 Nissan Maxima
I have a '96 Nissan Maxima. I very recently had my front brakes replaced, tires rotated (one was worn badly inside - replaced with used), balanced. After about 1 week I was driving approx 60mps when I heard a noise that sounded like muffler dropped and was dragging on ground. It wasn't. Noise was coming from left front tire. Very loud - sounded like something was loose and clunking around in wheel. I had it towed back to mechanic. He heard nothing, found nothing. Was able to drive with no problems. Noise did not return until I was coming down a hill and had to brake and make a left hand turn. Was not as loud. Drove about 5 blocks to home and parked it. Drove it later again with no issue until coming down a hill that curved to left and was slowing for a stop, it began again (the quieter version). Parked it about 3 blocks at home. Was gone when I drove it again. Had friend take off wheel, brakes could find nothing. Car and steering wheel also shake between 50 & 65mph. It did before brakes/tires replaced.
i suggest that you return the car to a mechanic and have a full inspection of the drive line done, including wheel bearings front and rear, noises can sound like there coming from one point , but can be somewhere else, if the noise is as loud as you say, something is very wrong and it should be located and repaired as soon a possible.'
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
