Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1985 Honda Civic
Auto Repair1999 Jeep Cherokee Loss...
Auto Repair1994 Other Hyundai Model...
Auto Repair2001 Oldsmobile Alero W...
Auto Repair2002 Saturn Sc2 Slave C...
Auto Repair1991 Other Hyundai Model...
Auto Repair1995 Honda Accord How T...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1996 Nissan Altima will not start but turns over
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Sun Jul 06, 2008 6:01 am
By mjones1010, New to the forum
Give Feedback | Votes: 0
Engine Performance problem
1996 Nissan Altima 4 cyl Two Wheel Drive Automatic 240000 miles
While turning the car over it sometime attemps to start.
The mass control sensor has been change,spark plugs, wires, fuel filter, rotor and filter all have been changed.
What could the problem be.
Thanks
Find a car repair manual for your Nissan Altima Repair Question.
By Advertisment,
Posted at Sun Jul 06, 2008 6:11 pm
By BMRFIXIT, Tech level 10
Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9Reputation: 463.9 (464) Give Feedback | Votes: 16
Check for spark
check fuel pressure
what is missing
start with fuses and relays
crank sensor fuel pump
and the list goes on and on
check for codes
check spark
check fuel pressure
check timing
let us know what is missing
Posted at Mon Jul 07, 2008 7:24 pm
By mirom2, Likes cars!
get yourself some starting fluid and open the airbox, and spay a few sprays into tube above filter, close up and try to start, if it starts and dies, the you have a fuel delivery issue, read the rest of the post and it could save you some cash, email me if any questions...
Hi, I have had a similar issue, took the car to a shop they replaced a bunch of parts that they said were definitely bad, but thats another story, they gave me a BS story each time they replaced something, and i am talking a reputible shop in town here, not some joe shmo, found the issue myself after doing some thinking, if you cannot start car, have someone else turn key for you and you listen from backseat with the larger half of the seat folded forward, the fuel pump is right below where the velcro connects the trunk carpet right below there, but to get to it back seat comes out, along with the round pressed metal surround under the plastic pieces there along with them... anyways listen for the fuel pump as the other person turns key, you cant do this test yourself. if you hear nothing, its most likely it, try a few times, then get out and rock the car back and forth a couple times from side to side, at this point the wire which is half broken inside may align itself, try listening again, if you are able to start car, then get the sending unit or fuel pump harness kit, forget which it was, but the wire that is bad is the one that connects to top of the fuel tank seal and the other side to the fuel pump. I hope this saves a lot of headaches for everyone, and I can't believe that nissan doesnt even have this documented... definite design flw, basically what happens is while driving the sending unit along with fuel pump are suspended by 2 fuel lines and this wire harness, and it, just like any piece of metal eventually partially breaks when folded back and forth a thousand times...i dont believe you can buy the cable itself, it comes as a part of the kit or sending unit, one connector is flat, other square with rounded corners, i believe around 80$ bucks at nissan dealer only.... good luck, let me know how it works out...
-Miro
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
