Brakes problem
1996 Nissan 240SX 4 cyl Two Wheel Drive Automatic 123000 miles
recently I had my master brake cylinder replaced so the whole brake system was flushed and new fluid was replaced. I put new brake pads on the rear wheels and now the rear brakes don't feel like they are working right.The rear brakes were working fine before I changed the pads. I didn't put lube on the caliper sleeves I know its not the master brake cylinder because its new. how do I troubleshoot this? Oh if you pull the e-brake the car will stop on the side of a hill but even the e-brake seems weak. and I did adjust the e-brake so it would work with the new pads.
