Car Repair Chat - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1996 Mitsubishi Eclipse Car dies and will not start back
Posted at Sat Nov 07, 2009 11:38 am |
By
abcaldwe,
Have Donated |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1996 Mitsubishi Eclipse 4 cyl Front Wheel Drive Manual 171000 miles
I have a 1996 Mitsubishi Eclipse RS 2.0L Non Turbo 4 cylinder engine code 420A that has me baffled. When I start the car after it has cooled or not been started in a while it starts up fine and runs good. The problem is that when it runs for a while it dies and will not start again until it cools for a bit. The water temp gauge doesn't really mean anything to it as far as warm and cool because the temp comes up pretty quick on the gauge and the car will run maybe 10-15 mins and then stumble and shut off. When I try to start it back, it sounds like it tries to fire and sputters a little bit but will not stay running. I have put a new Ignition Module on it, new wires, new plugs, fuel filter, new automatic shutdown and fuel pump relays and a new upstream oxygen sensor. I check the fuel pressure at the rail and it holds a steady 50 psi even when the car shuts off so it doesn't seem to be a fuel pump or fuel pressure regulator issue. Could it be the downstream O2 sensor or the catalytic converter? Thank you for the website and thank you in advance. |
Find a
car repair manual for your Mitsubishi Eclipse Repair Question.
Posted at Sat Nov 07, 2009 12:03 pm |
By
rasmataz,
Certified 2CarPros Master Technician |
        (8489) Give Feedback | Votes: 230 |
Hi abcaldwe and TY for the donation
The problem is that when it runs for a while it dies and will not start again until it cools for a bit. Don't wait for it to cool do below immediately to catch if its fuel or spark problem.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
