Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1995 Ford Explorer Fast...
Auto Repair1990 Geo Prizm Head Gas...
Auto Repair2004 Gmc Envoy Changing...
Auto Repair2000 Volkswagen Jetta F...
Auto Repair1997 Ford F150 4x4 Not ...
Auto Repair2002 Mitsubishi Diamante...
Auto Repair2003 Nissan Altima Misf...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1996 Mercury Sable service engine soon
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Aug 29, 2008 6:11 pm
By twinkel, Likes cars!
Give Feedback | Votes: 0
Computer problem
1996 Mercury Sable 6 cyl Front Wheel Drive Automatic 142000 miles
a trouble code of P0430 came up. what do i need to check for in bank 2. i would like some insight on this subject before i take the car to a exhaust shop.
Find a car repair manual for your Mercury Sable Repair Question.
Posted at Sat Aug 30, 2008 1:36 am
By mhpautos, Certified 2CarPros Master Technician
Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8Reputation: 516.8 (517) Give Feedback | Votes: 11
Hi there.
The catalytic converter has an oxygen sensor in front and behind it. When the vehicle is warm and running in closed loop mode, the upstream oxygen sensor waveform reading should fluctuate. The downstream O2 sensor reading should be fairly steady. Typically the P0420 code triggers the Check Engine Light if the readings of the two sensors are similar. This is indicative of (among other things) a converter that is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions system.
A code P0420 may mean that one or more of the following has happened:
Leaded fuel was used where unleaded was called for
An oxygen sensor is not reading (functioning) properly
The engine coolant temperature sensor is not working properly
Damaged or leaking exhaust manifold / catalytic converter / exhaust pipe
Retarded spark timing
The oxygen sensors in front and behind the converter are reporting too similar of readings
mark (mhpautos)
Posted at Sat Aug 30, 2008 7:59 am
i drive like 2 minutes to work, would driving a very short distant make it go off because the car doesnt warm up.
Posted at Sat Aug 30, 2008 3:01 pm
Hi there,
The short drive in it's self should not make it go off, i feel that the up stream O2 sensor may be clogged and is causing your problem,
Mark(mhpautos)
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
