Engine Mechanical problem
1996 Lincoln Continental V8 Front Wheel Drive Automatic 127,00 miles
Trying to replace the tensioner pulley. It appears to need a 3/8 breaker bar to rotate the tension off but the bolt is on the back of the tensioner. How can you get to it and how can you change out the entire tensioner. Its mounted to the power steering pump. Do i have to remove the pump as well? The idler pulley is fine as the bolt is easily accesible.
