Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
THE FRONT DOOR HANDLE OUTSIDE ON BOTH DOORS WILL NOT OPEN DOORS WHEN THE DOORS ARE UNLOCKED HOW DO YOU REMOVE INSIDE PANEL TO GET AT LOCKS? WHAT WOULD CAUSE THIS PROBLEM
DO YOU HAVE ANY PICTURE?
Find a car repair manual for your Lincoln Continental Repair Question.
If the door latch will not open the door, but you can still use the keyless entry (key pad) to open the doors, then your problem is a broken plastic latch, that connects to the locking mechanism to the rod that is actuated by the door handle. It is buried down by the door lock mechanism. A Chilton, or a Hayes manual will have a diagram, the part can be purchased at any Ford dealership. it is about $6 USD.. FYI, the P/N in the manual is incorrect. I will check on it.. --- Alfredo
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
