Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1996 Jeep Wrangler 6 cyl Four Wheel Drive Manual
What symptoms can be expected from fuel getting into the crankcase?
Besides Piston wash and bearing damage, I would like to know what to look for as far as power,Exhaust ect.
Thanks.
Extremely rich. Besides what you mentioned about pison wash you can change the critical chamfer gap on the valves. Heavy carbon buildup on the spark plugs. Detonation might occur in the cylinders due to increased compression/smaller area because of carbon buildup. Catalytic converter(and maybe even the muffler) can become completely clogged, EGR valve can become inoperable. CCV system will actually draw a significant amount of hydrocarbon vapors into the intake that could cause gum and varnish buildup and throw off the MAP sensor.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
