1996 Jeep Laredo noises from the driver side front tire
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Noises problem
1996 Jeep Laredo 6 cyl Two Wheel Drive Automatic 200000 miles
I" getting noises from around the front driver side tire, someone said it's the cv drive shaft. However I have yet to locate a cv drive shaft. my question is where is the cv drive shaft? On my model car?
you don't have a cv joint on yours because yours is 2 wheel drive now is this noise when you hit a bump or just driving if it is when driving what your hearing is the hub bearings they are easy to replace if you need I can talk you through it if it is when you hit a bump then it is a ball joint
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
