Car Repair Forum - Ask a Question, Get a FREE Answer.
Go Back
1996 Jaguar XJ6 Rough Riding..
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Tue Dec 02, 2008 9:53 pm |
By
jameslucas83,
Have Donated |
Give Feedback | Votes: 0 |
Suspension problem
1996 Jaguar XJ6 6 cyl Automatic 168000 miles
I just replaced Front and Rear Shocks (Bilsteins). All 4 new tires just bought them not even 6 months ago. I had the transmission mount adjusted so that it's positioned properly. I had the engine mounts replaced 3-4 months ago with a tune-up. Rear differential was replaced with a rebuilt.. everything runs beautifully and smooth. I feel the harshness of rough road bumps also the car kinda shakes on the freeway if I take it to 70mph. The whole car kinda shakes a bit when riding in the car...i can see my rear view mirror shaking when driving also.
Please help!! I want the original ride and feel of my luxury car..
James Lucas
| Find a
car repair manual for your Jaguar XJ6 Repair Question. |
Posted at Wed Dec 03, 2008 8:11 am |
By
jameslucas83,
Have Donated |
You didn't really answer my question thoroughly...
I bought the Bilsteins over at Autozone. They are the heavy duty ride mono tube gas pressurized shocks for both front and rear. The shocks work smoothly but the car gives off a slight vibration when on the freeway. I want the feel of a brand new luxury car. What are the recommended tire pressure setting for a 1996 Jaguar Xj6? Where can I get a replacement manual that suppose to come with the car?
| Find a
Posted at Wed Dec 03, 2008 1:36 pm |
By
jameslucas83,
Have Donated |
What's Nos? is that the part number...
if so, the fronts are - Part Number: B36-1861
the rears are - Part Number: B46-1858
They are the Heavy duty ride -Mono tube gas pressurized shock.
I bought them through Autozone.
By the way... I just notice the vibrations have gotten a little louder..it seems that when I accelerate, I hear a mild noise..sounds like the axel working hard.. and i can feel the vibration through the steering wheel. I am concerned that this is a sign of an upcoming major problem that I need to address before it gets worse and really expensive..
| Find a
Posted at Fri Dec 05, 2008 5:38 pm |
By
mhpautos,
Certified 2CarPros Master Technician |
                          (549) Give Feedback | Votes: 12 |
Hi there,
Finally got an answer on the shockers, they are the standard replacement shocker for your car, so now we will have to investigate the actual suspension, have all the front end bushes been check for problems, and the vibration in the steering, will also be a front end related problem, have all the steering linkages checked, ball joints, inner bushes, wheel bearings, Is there a vibration when breaking, is it worse then? is there a leak in the power steering system? check these out
Mark (mhpautos)
| Find a
Posted at Tue Dec 09, 2008 7:43 am |
By
jameslucas83,
Have Donated |
I finally decided to go the extra mile to get a Full Diagnostic Inspection and to do and Enginine Compression test over at a non-dealer Jaguar Mechanic. I have mentioned these problems to several mechanics - that you mentioned and I think that they won't look at it...i'm not sure why? too tedious? or they don't feel like doing it?....It sucks to find a good mechanic!! ++ and want me to spend between $150-200. I think that doing a Full diagnostic Inspection and an engine compression test will show what problems there are mechanically. Do you think that is a good idea ?
| mhpautos wrote: | Hi there,
Mark (mhpautos) |
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
