Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1996 Honda Prelude 4 cyl Two Wheel Drive Automatic 121000 miles
My 96 prelude timiing belt broke, causing bent valves. A mechanic removed the head and had a valve job done on it. He changed the timing belt, water pump,plugs,wires,distributor cap,rotor and put it back together, but it ildes rough and is missing; plus it will not stay runing.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
