Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2001 Kia Sportage Vacuu...
Auto Repair1997 Ford Taurus 97 For...
Auto Repair2003 Gmc Envoy Door Swi...
Auto Repair1994 Nissan Maxima Bad ...
Auto Repair1992 Chevy Camaro Fuel ...
Auto Repair1995 Gmc Envoy Not Goin...
Auto Repair2003 Gmc Envoy 4 Wheel ...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1996 Honda Civic
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sun Sep 07, 2008 8:23 am
By eodmills, New to the forum
(11) Give Feedback | Votes: 0
Engine Performance problem
1996 Honda Civic 4 cyl Front Wheel Drive Automatic 165000 miles
I came to a complete stop and the car died. All the engine wants to do is just turn over but not start. I checked the battery volts and they were good. I checked for fuel but I couldn't tell if the pump was working because of surrounding noise. I replaced the rotor, the distributor cap and still got nothing. I checked the ignition coil and got proper ohms and I checked the ignition module and it had proper ohms also. If it is the timing belt, wouldn't I have heard more scary mechanical sounding noise because it is? an interferance engine? Anyway, any help will do.
Find a car repair manual for your Honda Civic Repair Question.
Posted at Mon Sep 08, 2008 9:46 am
By KHLow2008, Moderator
Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2 (179) Give Feedback | Votes: 13
Hi eodmills,
At slow rpm if the timing belt gives way, it would not emit much noise and there is a possibility the valves are not affected as it is supposed to be a non interference engine.
Remove distributor cap and crak engine, if rotor does not turn, the timing belt is buste.
Pull a plug wire out, attach a spark plug, ground it to the engine and get someone to crank and chack for sparks. If no spark, check fo faulty coil.
Unloosen 6mm service bolt on fuel rail and turn ignition on, if no fuel gushes out, check for faulty fuel pump or main relay.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
