Car Repair Chat - Ask a Question, Get a FREE Answer.
Go Back
1996 Honda Civic AC Clutch fuse blows
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Fri Jun 20, 2008 5:24 pm |
By
leigh-a,
Likes cars! |
Give Feedback | Votes: 0 |
Air Conditioning problem
1996 Honda Civic 4 cyl Front Wheel Drive Manual 111,00 miles
My AC had been working fine, and suddenly quit.
Found AC Clutch Fuse Blown. Tried new fuse, but blew shortly after switching on.
Clutch plate, outboard of pulley assy. turns freely, so compressor apparently not seized.
No visable shorted wires.
| Find a
car repair manual for your Honda Civic Repair Question. |
Posted at Mon Jun 23, 2008 6:18 pm |
By
leigh-a,
Likes cars! |
Thanks KLH.
(1) I removed + wire from clutch / system on- condensor fan worked / no blown fuse.
(2) Swapped Clutch & Condensor Fan relays ( same P/N)--- No changes.
(3) Connected jumper-wire, with in-line, 10 amp fuse direct from battery to clutch + wire. Clutch & compressor worked fine.
(4) Got very low voltage reading at wire from Thermal Protector (top of Sanden Compressor)
I'm not sure if the Thermal Protector is a device that's prone to shorting out, but there seems to be a short somewhere between the clutch relay and the output of the Thermal Protector/
Leigh
| Find a
Posted at Tue Jun 24, 2008 3:44 pm |
By
leigh-a,
Likes cars! |
Thanks for the reply KHL.
Could you tell me where the clutch coil is located.
Is it an internal component of the coil, in which case you would measure resistance across the + & - wires to the clutch? Does coil replacement mean clutch replacement?
Thanks in advance.
Best regards,
Leigh
| Find a
Posted at Mon Jul 28, 2008 3:26 pm |
By
cshampton,
New to the forum |
I am having a similar problem with my 1998 Honda Civic. I just spent right over $1200 to have my a/c compressor replaced (along with my timing belts and water pump at the same time) and when I got my car back, the air was blowing, just not cooling. When I took it back to the mechanic, he ended up discovering that the fuse was blowing. Everytime we replaced it and turned on the A/C switch, it would blow. He states that since it is electrical, it's not something he can do, but referred me to someone else. Before I go spend a ton of money at another mechanice, is the fuse blowing a result of something my mechanic did wrong when he installed the A/C compressor? or just a bad compressor? or something else? (This wasn't a problem before my compressor crapped out and was replaced.)
ANY assistance would be greatly appreciated. THANKS!
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
