Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1996 Honda Accord 4 cyl Front Wheel Drive Automatic 50,000 miles
i replaced the engine in my 96 accord Ex and since i have started the car it will jump RPM at idle from 0 to 1100 RPM. sometime i can put the car in nuteral and it will idle right and run smooth until you kill it. then it's starts all over again. diagnostics test which shows crank shaft sensor A replaced ang it didn't make a differents. the car surges when accerlating
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
