Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
P0507 is an idle control system, idle higher than expected.
With the two of these together it sounds like the front purge solenoid on the intake manifold is leaking and causing a vacuum leak through the EVAP system. It is a simple bolt on part that costs about 20 bucks. Two bolts to remove it and a clip that retains the vacuum line to the EVAP line. It could also be a larger vacuum leak though. Look for broken lines or listen for the leak as well when you test the solenoid valve.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
