Car Repair Talk - Ask a Question, Get a FREE Answer.
Go Back
1996 Geo Prizm engine misfires after warm
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Tue Sep 16, 2008 1:51 pm |
By
t_bone_u13,
Likes cars! |
Give Feedback | Votes: 0 |
Engine Performance problem
1996 Geo Prizm 4 cyl Front Wheel Drive Automatic 175000 miles
when the car idles it runs fine hot or cold, and the car runs great idle to redline when cold, but she problem shows up after the car warms up. thats when it starts to miss, and its no small miss, the motor sputters and cuts out on aceleration. i got the car from a friend who replaced all the ignition components and injectors to no avail. one other thing is that there is allot of black smoke on the bumper by the exhaust
| Find a
car repair manual for your Geo Prizm Repair Question. |
Posted at Wed Sep 24, 2008 5:39 am |
By
mmprince4000,
Moderator |
     (116) Give Feedback | Votes: 5 |
Have the car scanned at most autoparts stores for free.
The black exhaust indicates a rich mixture, this could be from a misfire, or a sensor out of range.
Generally, when you have a hot misfire, but runs OK cold, look at the ignitor (ignition module). Even though it is new, by what you have said, it can still be bad.
You want to get this fixed, because a rich mixture will ruin the convertor.
| Find a
Posted at Wed Sep 24, 2008 7:21 am |
By
t_bone_u13,
Likes cars! |
there are no codes on it. and i just replaced the ignitor and it didnt change it at all. i bought one of those obd2 recorders and it looks like the fuel system is getting goofy when it happens. the graph shows it dropping to near zero and spiking after. could it be the fuel pressure reg, on even maby the computer?
| Find a
Posted at Thu Sep 25, 2008 6:03 am |
By
t_bone_u13,
Likes cars! |
| mmprince4000 wrote: | Check the fuel pressure regulator by removing the vacuum line, if gas is present, the FP diaphram is ruptured and needs to be replaced.
Could also be a fuel pressure problem, or possibly the ECM. |
i looked in the line and didnt see any gas, but my nose is plugged so i will have a friend sniff it. can it go bad even if there isn t any gas in the line?
the more i dig into it the more it seems like its the computer. i put a live scaner on it again, and it said that fuel system bank one was closed and bank 2 disabled. are there 2 banks in a 4 banger or does it say disabled because its not present. for bank 1 it seems to allways say closed no matter what throttle position.
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
