Transmission problem
1996 Ford Thunderbird V8 Two Wheel Drive Automatic 103000 miles
trans reveves up between 1st & second does aventually goes in gear or shift it manually. overdrive light blinks on&off,engine check light comes on also. had diagnostic done by trans shop & code for speed sensor comes up. they replaced both input & output sensors didnt help. trans has had reguler services done over the years. fluild is pink. trans shop removed trans pan & is as clean as new. I think its in electronics related. trans has worked so good over the years. any ideas ? thanks any help would be great. Dale
