Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1996 Ford Thunderbird ignition
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Aug 12, 2008 11:03 am
By branducci, New to the forum
Give Feedback | Votes: 0
Engine Mechanical problem
1996 Ford Thunderbird V8 Two Wheel Drive Automatic 155000 miles
how can i change out my ignition tumbler?
Find a car repair manual for your Ford Thunderbird Repair Question.
Posted at Mon Aug 18, 2008 7:48 pm
By RyanBlizz, Likes cars!
You are talking about where the key goes in right? It is very easy if you have the old key.
Disconnect your battery, put your key into the ignition, turn to acc (1 turn), then push a very small screw driver into the hole directly under the ignition. This might take you a little while to get it lined up correctly, but there is a little pin that pushes in. You can actually lay on the floor mat with a flash light and see it if you have trouble.
Once you push the pin in, just pull the ignition outwards, don't turn - just pull straight out.
A new ignition switch is around $15 at your local auto parts store, and takes just a second to slide into position.
Just FYI, my 1995 thunderbird had a dealer or factory installed anti-theft device. It was a 1/2 thick aluminum plate all the way around the ignition switch. I had to finally drill four rivets to take my ignition out. This was the only one I have ever seen like this, but just letting you know in case you have a special one too.
Ryan
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
