Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1996 Ford Taurus 6 cyl Front Wheel Drive Automatic 174,00 miles
The car is a 1996 ford station wagon. I check the compression in the front row of cylinders. The first two were 150, 130, the last one (drivers side) read 60psi.
I checked the compression when the motor was cold. The car has a long crank before it starts. My question is head gasket blown on the inside or is it the valves or rings.
You can do a wet comp test, warm the engine up and remove all plugs, add a small amount of engine oil to the cyl to be tested just enough to coat the rings as this will temp seal them, do the comp test, if the comps come up the rings are faulty, if the stay about the same it will be a valve or a head gasket problem, try this.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
