Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2001 Chevy Cavalier Que...
Auto Repair1997 Chrysler Town And C...
Auto Repair1998 Saturn Sw2 Where T...
Auto Repair1998 Nissan Pathfinder ...
Auto Repair2000 Ford Truck Front W...
Auto Repair1994 Bmw 325 Radiator Fan
Auto Repair1997 Chrysler Sebring
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1996 Ford Ranger center bearing on drive shaft
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Nov 28, 2008 5:10 pm
By ranger danger, New to the forum
Give Feedback | Votes: 0
Drive Train Axles Bearings problem
1996 Ford Ranger 4 cyl Two Wheel Drive Manual 151000 miles
Will I need any spesial tools to change the bearing?
Find a car repair manual for your Ford Ranger Repair Question.
Posted at Fri Nov 28, 2008 5:23 pm
By Dave H, Moderator
Reputation: 97.5Reputation: 97.5Reputation: 97.5Reputation: 97.5Reputation: 97.5 (97) Give Feedback | Votes: 5
AXLE SHAFT & BEARING
Removal
CAUTION:DO NOT damage "O" ring in axle shaft groove under "C" lock.
Raise and support vehicle. Remove wheel assemblies and brake drums. Remove housing cover, and drain lubricant. Remove differential pinion shaft lock bolt and remove pinion shaft. See Fig. 2 . Push axle shaft inward and remove "C" locks.
Remove axle shaft, being careful not to cut axle seal. Using a slide hammer and puller, remove bearing and oil seal as a unit.
Fig. 2: Exploded View Of Differential Axle Housing & Components (Typical)
Courtesy of FORD MOTOR CO.
Installation
Lubricate bearing with rear axle lubricant. Using a driver, install bearing. Install oil seal. If seal becomes cocked during installation, remove seal and replace with a NEW one.
Carefully insert axle in housing to avoid damaging oil seal. Install "C" locks, and push shafts outward to seat locks in counterbore of differential side gears.
Install pinion gears and thrust washers (if removed). Turn gear assembly to align pinion gear and thrust washer bores with pinion shaft holes on case. Install pinion shaft. Apply Loctite to lock bolt, and tighten to specification. See TORQUE SPECIFICATIONS .
NOTE:Ranger uses a reusable metal housing cover. Silicone sealant is used and cover must be installed within 15 minutes of sealant application.
Clean gasket mating surfaces and apply 1/8 - 3/16" wide bead of silicone sealant on axle housing cover. Install housing cover. Tighten cover bolts to specification in a crisscross pattern. See TORQUE SPECIFICATIONS . Fill differential until fluid level is about 1/4" below bottom of filler plug hole.
Posted at Mon Dec 01, 2008 11:57 pm
By brewcrew442, Likes cars!
When you say center bearing on the drive shaft it makes me think you mean the carrier bearing and not an axle bearing. Worlds apart. The carrier bearing is found where the front and rear parts of a two piece driveshaft meet and is bolted to the truck. The drive shaft goes through the center of it and it supports the shaft. I have a 94 Ranger supercab and have replaced mine before.
If this is what you mean then yes, you need a press to replace it. If you don't have access to one most garages or machine shops will do the work for a nominal fee, just take the shaft and a new bearing in. It only takes a few minutes.
Removing the shaft from the truck doesn't take anything more than a ratchet and a couple sockets. The actual removal and install of the shafts only takes about an hour if all goes well. Unbolt the u-joint straps and the two bolts holding the carrier to the truck and it's out.
Good Luck, hope this helps.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
