Auto Repair Forum - Ask a Question, Get a FREE Answer.
Go Back
1996 Ford Ranger Battery Light
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Wed Nov 19, 2008 8:19 am |
By
testond,
Have Donated |
Give Feedback | Votes: 0 |
Electrical problem
1996 Ford Ranger 4 cyl Two Wheel Drive Manual 197000 miles
Battery light on dash started coming on briefly, then would go out (sometimes for days). Now it is on constantly. Occasionally it will go back off at high rpms. I have replaced the battery. The charge meter on the dash looks fine (although it's not a great indicator), there are no issues under load (lights, etc), and no issues charging. I checked for loose wiring, ground wires and belt tension. I've been driving like this for weeks, without any issue, other than the battery light being on. Any thoughts?
| Find a
car repair manual for your Ford Ranger Repair Question. |
Posted at Wed Nov 19, 2008 5:39 pm |
By
m1ke,
Likes cars! |
| testond wrote: | Electrical problem
Battery light on dash started coming on briefly, then would go out (sometimes for days). Now it is on constantly. Occasionally it will go back off at high rpms. I have replaced the battery. The charge meter on the dash looks fine (although it's not a great indicator), there are no issues under load (lights, etc), and no issues charging. I checked for loose wiring, ground wires and belt tension. I've been driving like this for weeks, without any issue, other than the battery light being on. Any thoughts? |
I have the exact same truck, mine has 165k miles. I had the same problem you report with charging light flickering, then staying on. I had the alternator checked- it was bad. New one is on order.
| Find a
Posted at Fri Nov 21, 2008 3:41 am |
By
testond,
Have Donated |
Well, I checked the open voltage, and it was 12.78V. After starting the engine, now is 14.40V. This seems fine to me. Not sure where to go from here...
| Find a
Posted at Fri Nov 21, 2008 4:38 am |
By
m1ke,
Likes cars! |
Mine did the same thing.
I had it checked at an auto parts store, under load, and it indicated bad. As I drove it, the 'full charge' would come and go, but the new alternator fixed this.
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
