Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Car Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How to Use Test Equipment
Auto Repair Manual Car Maintenance Information
Vehicle Repair Service Engine Soon Light
Vehicle Repair Car Parts and Equipment Store
Vehicle Repair How Does it Work?
Vehicle Repair Safety Inspection
Auto Repair Manual Online Car Repair Manual
Vehicle Repair Smog Test Preparation
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1998 Ford Fairmont
Auto Repair1991 Toyota 4runner No ...
Auto Repair1997 Mitsubishi Eclipse ...
Auto Repair2006 Buick Rendezvous S...
Auto Repair1995 Lincoln Town Car C...
Auto Repair1993 Toyota Corolla Tra...
Auto Repair2002 Honda Accord Src
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1996 Ford F250 Stalls after start ONLY when revving & t
Welcome to our question and answer forum where over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Fri Apr 25, 2008 4:23 am
By TWMEANS, New to the forum
Give Feedback | Votes: 0
Computer problem
1996 Ford F250 V8 Four Wheel Drive Automatic 67500 miles
Dear Sirs,
I have a EXCELLENT 1996 F250 4WD H/D (Over 8500 GVW) with auto trans E4OD & 351W Engine all in near mint condition (it belonged to my father, who passed away 2 years ago, but maintained this truck obsessively) with ONLY 67500 MILES! But I know have a problem that has myself with approx. 20+ yrs of Ford tech experience that has me totally baffled & lost. (Remember, this is a OBD-I series EEC-IV ECM/PCM set up). Truck Starts perfectly fine, but when I rev the engine to approx 2500-3000 RPMS (truck has no factory tach) IT DIES. (Fuel pressure & regulator are perfectly in spec) I have made sure the intial timing is set correctly @ 10 degrees BTDC WITH the SPOUT REMOVED. When I replace the Spout connector the base timing is 'bouncing' up to 8 degrees, & has so much spark scatter while revving till it quits, I cannot see what the timing is at before it dies at approx 2500-3000RPM EEC should only retard it bya couple of degrees static, not bouncing. Here is the REAL STRANGE PART, if I remove the Spout connector it will rev to the factory rev limiter (approx 6200 rpm) with NO problem, ONLY I am NOT getting ANY TIMING advance w/o the Spout installed. I have done the KOEO & KOER EEC-IV Test & KEEP getting CODE 211 (PIP FAILURE) I have REPLACED with the correct TFI Module (its the black one that is remote mounted on inside fenderwell AND is the CCD type (computer controlled dwell) TYPE (Denoted by Black color TFI) NOT the GRAY TFI which is Fords 'Push To Start' TFI Module. I have already been thru that Ford's stupid set-up, whether it is distributor mounted TFI or remote mounted TFI(closed bowl distributor). I have REPLACED the ENTIRE Distributor (the correct one with the correct steel cam gear) to totally rule out any IDM failure (which is closely related to the spout system & controlled by the CCD (black) TFI Module.) The Gray TFI's DO NOT USE THE IDM System (Ignition Diagnostic Module) I have checked & rechecked the wiring system for shorts, loose connectors etc., remember this truck only has 67K actual miles on it. Unfortuneatly I do not have acess to a 'Break-Out-Box' to further investigate the problem. I have cleared the ECM's KAM (keep alive memory, several times) of the ECM & KEEP GETTING the same CODE of 211 (PIP Failure, or Double PIP signal received, shutting down the truck). I am at my witts end. The only thing that I can think of is the actual ECM/PCM is in need of replacement, as it controls the initial timing once it is set correctly by removing the Spout connector & setting it & replacing it. It Should only change the base initial timing by only a few degrees at idle (but remember mine is BOUNCING AT LEAST 8 Degrees whne the spout is replaced. Then it is taken over by the set table inside the ECM by all of the various sensors that OBD-I use. HELP Me if you think you can, as I have NEVER seen this type of Ford Problem, OBD-I or Even with an OBD-II for that matter. FYI, the MIL (Check Engine light, NEVER COMES ON) and it is NOT in the 'LIMP HOME MODE' (code 998 I think) ANY IDEAS??? Sincerely Tony
Find diagnostic tools, replacement parts or locate a car repair manual for your Ford F250 Repair Question.
By Advertisment,
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
