Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Engine Cooling problem
1996 Ford F150 V8 Four Wheel Drive Automatic 109000 miles
Hello
I noticed coolant spraying onto the engine. Took to local mechanic who found coolant coming from what they thought was a freeze plug on the throttle body They say they cannot get a new or used throttle body for replacement but will "work on it" OR can install a used throttle body from a different size [larger] engine.
Local Ford dealer said they don't don't replace throttle bodies for this engine.
Please advise?
Thanks
Why dont they replace them? I have had to for being worn out and for coolant erosion. Have you seen where the leak is for yourself? Might want to just so you can explain to the Ford parts guy what it is you need, I dont recall there being a freeze plug on the throttle body, and if there is, it should be serviceable
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
