Transmission problem
1996 Ford Explorer 6 cyl Four Wheel Drive Automatic 146000 miles
my ford explorer sport has developed a shifting problem. the overdrive started to flash intermittently and vehile will not go into overdrive and when you put it in reverse it will not back up until you get to 2000rpms and then it backs up.put it on code machine and pcm module keeps coming up and also 2nd and 3rd gear ratio's////any ideas
