Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Automobile Safety Inspection
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair1986 Honda Prelude No S...
Auto Repair2005 Pontiac G6 A/c Com...
Auto Repair2002 Honda Civic Headli...
Auto Repair1995 Ford Explorer Tran...
Auto Repair1995 Chevy S-10 Dash Re...
Auto Repair2009 Toyota Corolla A C
Auto Repair1999 Cadillac Deville B...
Auto Repair More Repair Topics...
Car Repair Advice by Professional Automotive Experts
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1996 Ford Explorer Fuel mileage and re-flashing
Posted at Fri Nov 20, 2009 4:18 pm
By daefox, Have Donated
Give Feedback | Votes: 0
Computer problem
1996 Ford Explorer 6 cyl Two Wheel Drive Automatic 200017 miles
1996 ford explorer 2wd xlt fuel mileage just keeps getting worse.In the last year the milage went from 21.4 mpg city to 18 mpg city to 16.8 city. Highway went from 25.9 to 20.1 mpg. Took the truck in to find out why.They reflashed the computer and the milage went to 22 mpg city and 27.3 on the highway. I have done all the maintenance filters,plugs, fluids.air in the tires,plug wires. Two months after the computer re-flashing the mileage dropped off again.Any Idea of what is going on because the dealer just gives me the run around about the problem,Thought about a new computer or maybe water in fuel but there is no driveablilty issues. Also had transmission rebuilt at 175000 miles. thanks
Find a car repair manual for your Ford Explorer Repair Question.
Posted at Sat Nov 21, 2009 6:53 am
By racefan966, Certified 2CarPros Technician
Reputation: 2962.5Reputation: 2962.5Reputation: 2962.5Reputation: 2962.5Reputation: 2962.5Reputation: 2962.5 (2963) Give Feedback | Votes: 44
This can be caused by many things. Anything from a sensor to gas to injectors or? Now this engine does have a lot of mileage on it so you can expect new like mpg from it either. Now my first question is how old is the fuel filter and spark plugs? Have you tried getting gas from a different station? Have you cleaned the mass air flow meter with mass air flow cleaner. Use only mass air flow cleaner on it too. Get back to me and we will go from there.
Posted at Sat Nov 21, 2009 11:34 am
Fuel filter replaced 8k miles ago,injectors cleaned and checked at dealership,new air filter,tried different gas from all over town minimal differences,spark plugs 12k miles ago along with plug wires and ignition pack.I checked compression cold and warm all cylinders cold are above 120psi and warm are close to 140psi.The compression gauge is just a cheap auto parts store type so precise readings are difficult.I changed the radiator fluid and thermostat and it helps some,nothing significant it could be just a change in driving .I will try the mass air sensor cleaner,did not know the made such a product.but what if that is not the fix?
Thanks Dave
Posted at Mon Nov 23, 2009 5:22 pm
So tell me have you cleaned the mass air flow meter? If not try it use only mass air flow cleaner. Let me know how it goes. If it don't change much then you will need a digital multi meter to check a couple of sensor ok.
Posted at Mon Nov 23, 2009 5:52 pm
Yes i did clean the mass air sensor.Found a very interesting thing.The housing that the sensor is attached to was not completely seated into the air intake /filter assembly.There was a broken tab cracked to be more precise.The whole mass air sensor assembly just plopped out, no clipped in secured seating. The last guy to play with that was the Havoline oil change shop,to check my air filter.Oddly I did have a spare assembly and sensor,cleaned it put it in and the truck even idles better.I do just pull random parts off of junkers that match up.Picked up the habit when I drove a VW fox.Thanks for your help It was worth every cent.
Posted at Mon Nov 23, 2009 5:59 pm
Great glad to hear it fixed and running better. If you have any other questoins just ask.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
