Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
1996 Ford Bronco V8 Four Wheel Drive Automatic 130000 miles
I am currently having some runability problems. It started suddenly. Runs good at idle and when under no load or very light accelration. but when under heavy load or accel it lays down. I checked the fuel pressure and with key on and not running I have a reading of 10 psi. when running at idle it is 20 psi and falls to about 17 under accel.. I suspect the pump is going bad because I have replaced the filter. what are the specs for fuel pressure for this vehicle and do you agree with the diag.?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
