Transmission problem
1996 Dodge Stratus 4 cyl Four Wheel Drive Automatic 120k miles
Hello, after 10-15 min driving, the car tursn or changes automatically running only on 1st, not changing to 2nd, 3rd or 4th.
It only happends after driving over 10-15 min. You may wonder if the car heats up, no does not, it has gas, oil and everything.
A mechanic told me it had something to do with the sensors; AutoZone told me to see the manufacturer vendor since this was a transmission issue.
Just need to know what is your expert opinion.
Is it a transmission problem or has something to do with sensors?
Please reply to me if you have any questions, I will answer quickly.
Thanks!
Find a
repair manual for your Dodge Stratus Repair Question.
Posted at Thu Apr 24, 2008 7:56 am
By
Advertisment,
Find a
P0401
inspect EGR vacuum lines inspect EGR valve gasket
inspect exhaust system for leak and repair
check EGR valve remove and clean if needed if sticking replace
check EGR solenoid and electric connection
inspect manifold and tube for restriction
check all hoses
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
