Auto Repair Talk - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1996 Dodge Stratus my car is overhating
Posted at Fri Jul 03, 2009 5:26 pm |
By
simon3755,
Have Donated |
(6) Give Feedback | Votes: 0 |
Engine Cooling problem
1996 Dodge Stratus 4 cyl Two Wheel Drive Automatic 56,000 miles
i changed the thermo stat. there is a leak not the radiator. i got in the car and drove and it overheated |
Find a
car repair manual for your Dodge Stratus Repair Question.
Posted at Fri Jul 03, 2009 6:18 pm |
By
buddycraigg,
Moderator |
(33) Give Feedback | Votes: 22 |
| simon3755 wrote: | | there is a leak not the radiator |
did you say you have a leak, but it's not in the radiator?
You're going to have to repair the leak before it will stop over heating. |
Find a
Posted at Fri Jul 03, 2009 6:46 pm |
By
simon3755,
Have Donated |
there is a leak not in gasket or radiator/ it just happened today/ i turned on the heat to pull from the egine it was not warm air/ it just started this today |
Find a
Posted at Fri Jul 03, 2009 7:04 pm |
By
buddycraigg,
Moderator |
| simon3755 wrote: | | i turned on the heat to pull from the egine it was not warm air |
That would be normal, the water was either too low to fill the heater core, or it was boiling.
You're still going to have to find the leak. |
Find a
Posted at Sat Jul 04, 2009 5:06 am |
By
simon3755,
Have Donated |
do you think it's the water pump? as soon as the car runs for like 2 minutes it overhaets and liquid poors out of the bottom by the oil filter |
Find a
Posted at Sat Jul 04, 2009 2:55 pm |
By
buddycraigg,
Moderator |
it could be the water pump, there is a hole in the bottom of most pumps. coolant will leak out of the hole if the pump is starting to fail.
Which 4 cylinder do you have? |
Find a
Posted at Sat Jul 04, 2009 3:00 pm |
By
simon3755,
Have Donated |
4/ it never leaked until the day it started overheating/ you cannot drive it because it overheats |
Find a
Posted at Sat Jul 04, 2009 3:04 pm |
By
buddycraigg,
Moderator |
which 4 cylinder engine do you have? |
Find a
Posted at Sat Jul 04, 2009 3:47 pm |
By
simon3755,
Have Donated |
2.4 |
Find a
Posted at Sat Jul 04, 2009 4:11 pm |
By
buddycraigg,
Moderator |
The 2.4 is known for early head gasket failures around the 50,000 mile mark.
And with your car overheating in just 2 minutes time. I suspect that is the problem. Sorry to have to give you bad news. |
Find a
Goto page 1, 2 Next
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
