Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Automobile Safety Inspection
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair1989 Other Chevrolet Mod...
Auto Repair1996 Ford Ranger Wiring...
Auto Repair1990 Chevy Cavalier Sta...
Auto Repair1998 Chevy Monte Carlo ...
Auto Repair2004 Land Rover Discover...
Auto Repair2003 Dodge Sx Tining Be...
Auto Repair1971 Ford F-100 Intake ...
Auto Repair More Repair Topics...
We are the Auto Repair Experts!
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1996 Dodge Ram Spark plug removal
Posted at Mon Oct 26, 2009 2:25 pm
By ivermcdriver, Likes to hang around!
(9) Give Feedback | Votes: 0
Engine Mechanical problem
1996 Dodge Ram V8 Four Wheel Drive Automatic 200000 miles
Hello, I have a problem with spark plugs (3 of them) all on the drivers side of a 1996 Ram with a 5.9L engine they broke off. Not the porcelain but they were so rusted the electrode with the 5/8s fitting snapped off. I got one out with a easy-out however the back two will not budge. Is their a way to remove the spark plug tube that goes around the spark plug.
Thanks
Find a car repair manual for your Dodge Ram Repair Question.
Posted at Thu Nov 19, 2009 10:05 am
By ramtough2001, New to the forum
I do not know how to pull the tubes. I ended up breaking them off (they break easily) right where they exit the head. I was hoping to pull them out and get a bolt remover around the round bottom ring of the plug, but I don't think removing them will even give enough clearance.
I have exactly the same problem. What appears to happen is that the washer is frozen to the head and to the remaining section of the plug. I have tried heat, freeze spray. penetrants, and ez-outs with no luck. Pulling the head seems to be the next course of action for me.
I was going to (carefully) try a hole saw in reverse to cut into that ring and maybe start it turning or at least loosen it a little so an ez-out will work. Let me know how you make out.
Posted at Thu Nov 19, 2009 2:53 pm
Hello ramtough2001,
I cut off tubes with dremel cut off wheel and it worked reel good then removed the brake booster (careful not to bend brake lines to far) then DRILL OUT what was left of the spark plug with a 1/2" bit, get a new one that will cut metal. It will be fairly easy to keep the drill at the same angle as the spark plug just pack the hole with a ton of greese. The washer will come out first real quick so watch for it then its removal of the old plug. Make sure piston is not at TDC before starting (I forgot after starting) Clear chips as best as possiable. Then you will have to re tap the head. All of this for a friends son!!! I took my time and cleaned over and over so no bits of metal got into piston chamber. Truck runs great now after having to be towed The spark plugs were never changed since new!! Best of luck with your truck
Posted at Fri Nov 20, 2009 4:16 am
Great idea! Thanks for the info. I will try this over the weekend. How do you get the ceramic section out of the plug before drilling it?
Posted at Fri Nov 20, 2009 1:28 pm
If the plug is still in the head put a socket on ratchet driver and turn till it busts off otherwise a small drift and hammer will take care of the ceramic stem.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
