Car Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1996 Dodge Ram engine does not run
Posted at Sat Nov 14, 2009 6:28 pm |
By
mbrock42,
Likes to hang around! |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1996 Dodge Ram V8 Two Wheel Drive Manual 225000 miles
Truck stoped running while I was driving. I think that it may have seased. Is there any way I can tell before I take it to the repair shop. |
Find a
car repair manual for your Dodge Ram Repair Question.
Posted at Sun Nov 15, 2009 9:20 am |
By
jdl123,
Moderator |
     (3071) Give Feedback | Votes: 93 |
Welcome to the forum. Remove the plugs and accessory belt/s, see if you can turn the crank by hand? All the fluids ok? |
Find a
Posted at Fri Nov 20, 2009 9:04 pm |
By
mbrock42,
Pulled plugs and belts, would not turn. The dip stick is stuck so cannt check hower it does have some oil I looosend the drain just to see if there was any. Whats the next step. Pull the engine? |
Find a
Posted at Sat Nov 21, 2009 6:58 am |
By
jdl123,
Moderator |
Did you notice anything before it siezed? temp lite-- oil lite-- anything? You can pull oil pan and heads, see if you see anything? That's up to you. |
Find a
Posted at Sat Nov 21, 2009 9:31 am |
By
mbrock42,
No. everything seemed normal. Thank you for the help. I'm going to pull the heads next. I'll keep you posted. Thank you for the time |
Find a
Posted at Sat Nov 21, 2009 11:20 am |
By
jdl123,
Moderator |
Just a thought, if you think the piston/s is siezed? With plugs removed, pour a little oil in each spark plug hole, let it set for a while, see if they come loose? Although the cylinders may still be damaged? |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
