Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
1996 Dodge Intrepid 6 cyl Two Wheel Drive Automatic
driving normal and then just cut off,tried a coil pack but no luck,doesnt sound like its not firing but not sure,can here fuel pump working----HELP
Confirm the actual fuel pressure by the use of a fuel pressure gauge designed for your system and comeback with the pressure readings-before we get into other areas-
we had this problem last year and it turned out to be the crank sensor. The fuel pressure was low, but acceptable. This year, the same problem is here again, but this time, there is no fuel pressure. I'm inspecting the fuel pump today.
The symptoms are the same (strong cranking), only this time I can't hear the fuel pump activate when I turn the key to "On".
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
