Welcome to our question and answer forum were over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Transmission problem
1996 Dodge Caravan 6 cyl Front Wheel Drive Automatic 200,00 miles
Our 1996 Caravan is stuck in limp home mode. It will not come out of second gear. We tried dropping the pan and changing the trans fluid and filter. This did not fix the problem. What should we do next.
Find a
repair manual for your Dodge Caravan Repair Question.
Posted at Mon May 12, 2008 6:03 pm
By
Advertisment,
Find a
Is your check or service engine light on? If it is have codes pulled. Does the speedometer work?
It is possible the either the Vehicle Input Speed Sensor is Bad or the Output Speed Sensor or maybe even both. They are very inexpensive so I would change them first.
If that doesn't fix it, it may be the TCM (Transmission Control Module)
It is also very possible the tranny is in need of a rebuild.
Post your response here....
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
