Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1996 Chrysler Van 6 cyl Two Wheel Drive Automatic 200935 miles
I was driving and I turned on my signal to make a right turn and as I was turning the corner, my wipers came on and stayed on even though the switch was off. I remeber it coming on one other time, but it didn't stay on. I checked the fuses but those were fine. please help...
HI:
It sounds like the switch has a short in it or there is a short in the steering column. The only way to check is to remove the steering wheel and get into the column itself. Most likely it's the switch.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
