Auto Repair Talk - Ask a Question, Get a FREE Answer.
Go Back
1996 Chrysler New Yorker brake issue
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Thu Aug 28, 2008 1:11 am |
By
lild1989,
Likes cars! |
Give Feedback | Votes: 0 |
1996 Chrysler New Yorker 113000 miles
while changing a tire my Chrysler fell off the jack . The axle went into the dirt. After I replaced the tire , and went for a test drive I heard a weird sort of grinding sound and found the brake pedal went down to the floor. It only stopped after a ton of pumping. I also got a brake light on. What could I have broken and how expensive will it be to fix.
| Find a
car repair manual for your Chrysler New Yorker Repair Question. |
Posted at Thu Aug 28, 2008 9:28 am |
By
lild1989,
Likes cars! |
I am 19 and don't have much money . Hoping to get this fixed without needing a second job. I checked and did not see any fluid leaking and the brake fluid level appears normal. Are there other brake related items in that area that I may have damaged besides brake line? Guess it's back to riding my bike to work for a while. BTW can someone wetting the ground near a car that is on a jack cause the car to slip?
| Find a
Posted at Thu Aug 28, 2008 2:28 pm |
By
mhpautos,
Certified 2CarPros Master Technician |
                         (517) Give Feedback | Votes: 11 |
Hi there,
If there is no fluid loss, that is a good sign, the grinding noise may be a bent backing plate rubbing on the disc, but the lack of pressure is a mystery i think you will have to get it inspected first hand by a mechanic as you often need to see first hand these problems, as for the car slipping off the jack, this will be due to the care not being positioned correctly, or it was jacked up on unstable ground, you should do this on concrete or the tarred road surface.
Mark (mhpautos)
| Find a
Posted at Thu Aug 28, 2008 4:54 pm |
By
lild1989,
Likes cars! |
we seem to have enough braking power to get to our local auto repair. we live in a small town thankfully , not much traffic. I think it may be time for a trade in and payment. My dad thinks it may be the master cylinder which sounds pricey.
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
