Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Transmission problem
1996 Chrysler LHS 6 cyl Front Wheel Drive Automatic 168000 miles
Hi, I have a Chrysler LHS, and I have been getting mided diagnosis from mechanics. The problem is that the car only shifts into first, and second gear. Then sometimes when going to fast like over thirty the car wil I guess drop out of gear. Then it slams back into gear and you can drive again. The problem is also that I need to replace the converters too. Would the converters cause the transmission to go into safe mode, and not shift up due to being fully clogged?
First things first, if you have clogged converters, and are pressing further down on the gas pedal, the input to the PCM from the throttle is too high, this will cause shifting symtoms...do the cats first, and fix the condition that caused the clog, or the new ones will clog!
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
