1996 Chrysler Concorde HOW TO CLEAR CODES AND COULD THEY BE
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Computer problem
1996 Chrysler Concorde 6 cyl Two Wheel Drive Automatic 152000 miles
HOW DO I CLEAR THE CODES IN MY 1996 CHRYSLER CONCORDE? ALL OF A SUDDEN MY A/C CLUTCH STOPPED AND MY COOLING FANS WORK SOMETIMES AND NOT OTHERS AND SOMETIMES ONLY ONE WORKS. WHAT IS GOING ON???
Find a car repair manual for your Chrysler Concorde Repair Question.
check if low on 134a gas
did u check the codes ? you should
cycle the key three times for the codes
disconnecting the battery will reset every thing including the codes
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
