Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Noises problem
1996 Chrysler Cirrus 4 cyl Front Wheel Drive Automatic 154000 miles
My car makes a loud clicking sound when i start it. I know that it is the starter not fully disengaging so i replaced the starter and sylinoid and its still making the sound. Could the problem be in the ignition switch? Also note that the car starts its not the sylinoid clicking its the starter moter gear and the flywheel making the clanking noise i know this because the old starter shows clear evidence of damage. I also had trouble with the lock cylinder freezing up and had to drill the thing out could this have damaged the ignition switch and caused this problem?
Last edited by kevinwalker8383 on Tue Nov 11, 2008 7:46 pm; edited 2 times in total
check that there is 12V the starter solinoid with the key on crank, ensure that there is 12V at the main starter terminal, check all battery terminals are clean and tight check earths clean and tight, if all is OK, the starter is faulty.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
