Car Repair Forum - Ask a Question, Get a FREE Answer.
Go Back
1996 Chevy Truck Why does my fuel pump keep dying?
Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Watch our new
Car Repair Video Series
with Ken Lavacot.
Posted at Sat Jul 05, 2008 3:02 pm |
By
rdcjb,
New to the forum |
Give Feedback | Votes: 0 |
Engine Performance problem
1996 Chevy Truck 4 cyl Two Wheel Drive Automatic 100000 miles
I have a Chevy 1500 and Since the end of May, I have replaced my fuel pump 3 times. I have also replaced the sending unit, wiring harness, fuel filter, 2 o2 sensors, the idle air intake valve, alternator, and fuel relay. After I replace the fuel pump, the truck runs great for about a wekk, then the check engine light comes, then about a week later, the engine dies and I have no fuel pressure and no power to the pump. What else should I check/replace to fix this issue?
| Find
diagnostic tools,
replacement parts
or locate a
car repair manual for your Chevy Truck Repair Question. |
Posted at Sun Jul 27, 2008 8:10 am |
By
powers009,
New to the forum |
| rdcjb wrote: | Engine Performance problem
I have a Chevy 1500 and Since the end of May, I have replaced my fuel pump 3 times. I have also replaced the sending unit, wiring harness, fuel filter, 2 o2 sensors, the idle air intake valve, alternator, and fuel relay. After I replace the fuel pump, the truck runs great for about a wekk, then the check engine light comes, then about a week later, the engine dies and I have no fuel pressure and no power to the pump. What else should I check/replace to fix this issue? |
My fuel pump on my 97 s10 went out recently it was an electrical problem that caused mine to go out. They also had to change a map sensor and the crank shaft sensor on it. Don't know if that will help.
| Find
diagnostic tools,
replacement parts
or locate a
Posted at Tue Aug 26, 2008 10:02 am |
By
hjc4604,
New to the forum |
Have you cleaned out the tank? There may be water or dirt clogging the pick-up filter in the tank. If the punp can't get fuel out it can burn out or may just not be able to pump since it can't pick up fuel. Is the pressure at the rail zero or does it have a low reading. I've had 2 pumps replaced in 200,000 miles. They seem to last about 100,000.
| Find
diagnostic tools,
replacement parts
or locate a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
