Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2001 Dodge Ram All Even...
Auto Repair1987 Mercedes Benz 560sl...
Auto Repair2003 Honda Accord Headl...
Auto Repair1998 Dodge Intrepid
Auto Repair1994 Mercury Sable Belt
Auto Repair2001 Gmc Sierra P0342 C...
Auto Repair2004 Chevy Cavalier Eng...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1996 Chevy Truck random cylinder misfire code
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Thu Nov 20, 2008 4:15 pm
By madmichial, Have Donated
(11) Give Feedback | Votes: 0
Engine Performance problem
1996 Chevy Truck V8 Front Wheel Drive Automatic 175000 miles
When driveing on the highway if I shift into 3rd gear as if pulling my boat the truck starts lungeing and service engine light blinks then stays on. It will also do this if put in first and and drive at 3000 to 5000 rpm. The code is a rondom misfire code
Find a car repair manual for your Chevy Truck Repair Question.
Posted at Fri Nov 21, 2008 12:31 am
By ImpalaSS, Moderator
Reputation: 153.4Reputation: 153.4Reputation: 153.4Reputation: 153.4Reputation: 153.4Reputation: 153.4Reputation: 153.4Reputation: 153.4 (153) Give Feedback | Votes: 7
Hello –
First, please give me the specific model of your truck as there are about 20 different ones. Is it a 1500 -2500 etc pick up, a Tahoe, Suburban etc. Then I need the specific engine in liter and the 8th digit of your VIN. Is this a 2WD or 4WD. Then is it an automatic or manual….the confusion there is the post states automatic and then you discuss shifting into 3rd.
I want to make sure we are talking about the same item to better assist you.
First I know you told me what the code was, but I need the specific code number to better assist you. So please go to Auto Zone or O’Reilly’s and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery, alternator and starter.
When was the last time you did a tune up….plugs, wires, fuel filter?
We don’t need to do a fuel pressure check yet based off of your code, but we may need to later.
Please do the above and provide the information requested and we can take it from there.
Thanks for the donation
Please let us know if what the final fix was for your car so we can better assist others. Thanks!
Find a car repair manual for your car repair questions.
Posted at Fri Nov 21, 2008 5:00 am
The truck is a 1996 chevy 1/2 ton 4x4 w/5.7 auto trans the eighth is an R
I have changed plugs,wires,cap and rotor ,O2 sensors trying to correct this.
The shifting to third that I spoke of is putting trans in third (out of overdrive)that is done when pulling trailers.
I have taken to auto zone do not have the exact code
Seems to have a slight surge in OD leading me to think TPS. maybe?
Posted at Fri Nov 21, 2008 5:01 pm
Hello –
Thanks for the update….
Without the exact code I would be searching thousands of codes…..that is how they are listed. So unless I am able to get that we will have to kind of search around.
The TPS is a possibility --- so is the MAP….I have attached info for both for your review.
I might also suggest talking to a transmission shop – sometimes it is a small fee for a diagnostic check. The transmission will also throw codes.
MANIFOLD ABSOLUTE PRESSURE (MAP) SENSOR. This sensor is mounted on or connected to the intake manifold to monitor intake vacuum. It changes voltage or frequency as manifold pressure changes. The computer uses this information to measure engine load so ignition timing can be advanced and retarded as needed. It performs essentially the same job as the vacuum advance diaphragm on an old fashioned mechanical distributor.
On engines with a "speed density" type of fuel injection, the MAP sensor also helps the PCM estimate airflow. Problems here may cause an intermittent check engine light (light comes on when accelerating or when the engine is under load), hesitation when accelerating, elevated emissions and poor engine performance. The engine will run with a bad MAP sensor, but it will run poorly. Some PCMs can substitute "estimated data" for a missing or out of range MAP signal, but engine performance will be drastically reduced.
MAP Sensor Strategies: Some MAP sensor problems are not the fault of the sensor itself. If the vacuum hose that connects the MAP sensor to the intake manifold is loose, leaking or plugged, the sensor can’t produce an accurate signal. Also, if there is a problem within the engine itself that causes intake vacuum to be lower than normal (such as a vacuum leak, EGR valve that’s stuck open or leaky PCV hose), the MAP sensor’s readings may be lower than normal.
THROTTLE POSITION SENSOR. Mounted on the throttle shaft of the carburetor or throttle body, the throttle position sensor (TPS) changes resistance as the throttle opens and closes. The computer uses this information to monitor engine load, acceleration, deceleration and when the engine is at idle or wide open throttle. The sensor’s signal is used by the PCM to enrich the fuel mixture during acceleration, and to retard and advance ignition timing.
Throttle Position Sensor Strategies: Many TPS sensors require an initial voltage adjustment when installed. This adjustment is critical for accurate operation. On some engines, a separate idle switch and/or wide open throttle (WOT) switch may also be used. Driveability symptoms due to a bad TPS can be similar to those caused by a bad MAP sensor: The engine will run without this input, but it will run poorly.
Posted at Fri Nov 21, 2008 5:45 pm
I will get the exact code and get back to you.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
