Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Cooling problem
1996 Chevy Tahoe 6 cyl Four Wheel Drive Automatic
My 1996 Tahoe has started making a high pitched noise on start up and accelerating. It also has been overheating once and a while. This morning while taking the kids to school the temperature gage went from low to almost in the red. I had the heater on and it was blowing cold air. After a couple of minutes the hot air finally started to flow and the temperature gage went back down. The tech at the local auto parts store said the noice sounds like the AC compressor is bad and said to run the belt without going in the compressor. The overheating he said was probably the water pump. Does this sound right? I am clueless when it comes to auto repair.
The squeal will normally be a faulty drive belt, and the overheating may be faulty thermostat, i would have these checked first along with a cooling system flush.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
