Logo Automobile Information Add Site to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair Car Repair Manuals
Auto Repair How Does it Work
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Automobile Safety Inspection
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Table
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Auto Repair Auto Parts
Search Website
Recent Repair Topics
Auto Repair1994 Ford Taurus
Auto Repair1997 Dodge Stratus Powe...
Auto Repair1994 Pontiac Grand Am R...
Auto Repair1996 Honda Civic My Car...
Auto Repair2003 Chevy Truck Servic...
Auto Repair1995 Chevy Suburban Hoo...
Auto Repair1996 Saturn Station Wago...
Auto Repair More Repair Topics...
Car Repair Help by Professional Mechanics
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1996 Chevy Silverado fault code P0719
Posted at Fri Dec 07, 2007 10:00 am
By gordy, New to the forum
Give Feedback | Votes: 0
Computer problem
1996 Chevy Silverado V8 Four Wheel Drive Automatic 134000 miles
SERVICE ENGINE SOON LIGHT COMES ON, MAY STAY ON FOR SEVERAL DAYS. GOES OFF BY ITSELF
COMES AND GOES, COMES AND GOES.
SCANNER ALWAYS READS CODE P0719.
OF COURSE SCANNER CAN ALSO CLEAR CODE, BUT IT ALWAYS COMES BACK.
THIS CODE READS TORQUE/BRAKE.......
IS IT A TRANNY OR BRAKE CIRCUIT ISSUE ?
WHAT DO I NEED TO DO ?
Find a car repair manual for your Chevy Silverado Repair Question.
Posted at Sun Dec 09, 2007 12:31 pm
By dennyp, Certified 2CarPros Technician
(223) Give Feedback | Votes: 6
DTC P0719 Brake Switch Circuit -- Low Input Step
Action
Value(s)
Was the Powertrain On-Board Diagnostic (OBD) System Check performed?
Go to Step 2
Go to
Powertrain On Board Diagnostic (OBD) System Check (4.3L)
Powertrain On Board Diagnostic (OBD) System Check (5.0L and 5.7L)
2
Install the scan tool (tech 1) .
With the engine OFF, turn the ignition switch to the RUN position.
Important: Before clearing the DTCs, use the scan tool in order to record the Freeze Frame and Failure Records for reference. The Clear Info function will erase the data.
Record the DTC Freeze Frame and Failure Records.
Select Brake Switch on the scan tool.
Disconnect the brake switch connector from the brake switch.
Install a fused jumper from terminal C to terminal D of the brake switch connector.
Did the brake switch status change from Open to Closed?
Go to Step 5
Go to Step 3
3
Remove the BRAKE fuse.
Inspect the fuse for an open.
Refer to Electrical Diagnosis, Section 8.
Was the fuse open?
Go to Step 4
Go to Step 6
4
Inspect circuit 441 for a short to ground.
Did you find and correct a problem?
Go to Step 8
5
Replace the brake switch.
Refer to Brake Switch Replacement.
Is the replacement complete?
Go to Step 8
6
Inspect circuit 420 for an open.
Did you find a problem?
Go to Step 8
Go to Step 7
7
Replace the VCM. Refer to Section 6:
VCM Replacement/Programming (4.3L)
VCM Replacement/Programming (5.0L and 5.7L)
Go to Step 8
8
In order to verify your repair, perform the following procedure:
Select DTC.
Select Clear Info.
Ensure that the following conditions are met:
- With the engine OFF, the ignition switch is in the RUN position.
- The brake pedal is not depressed.
- The VCM brake switch signal indicates Closed (12 volts) for 2 seconds.
Select Specific DTC. Enter DTC P0719.
Has the test run and passed?
System OK
Begin the diagnosis again. Go to Step 1
this flow chart is for a gas engine with a 4L60E transmission. If yours is different,let me know.I can get you the other charts.
Posted at Thu Dec 13, 2007 6:29 am
THIS WAS MY QUESTION, I JUST WANTED TO LET EVERYONE KNOW WHAT THE PROBLEM WAS.
READING THROUGH THE TROUBLE SHOOTING PROCESS, TWO THINGS ARE MENTIONED, A FUSE & THE SWITCH, A BLOWN FUSE DOES NOT COME AND GO. A BAD SWITCH COULD CERTAINLY PLAY GAMES. I PUT IN A NEW SWITCH UNDER THE DASH, PROBLEM SOLVED.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Computer Repair Question l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
