Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Drive Train Axles Bearings problem
1996 Chevy Silverado V8 Four Wheel Drive Automatic 116000 miles
What do I have to do to remove the rear axle. Do I have to go into the rear end to take it apart? Is there a retainer ring in there or some type of holding apparatus?
If you have never done this, and you happen to have a limited slip differential, you are probably in over your head. If you have a non ls rear end, yes, you need to remove the rear cover, remove the lock pin, push the axle in until the C clip fall out, then pull the axle. DO NOT turn the axles!
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
