Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
1996 Chevy Monte Carlo 6 cyl Front Wheel Drive Automatic 240000 miles
My problem is when I drive for a while or my car idles for a extended amount of time or if I drive in heavy traffic the engine temperture go's up and when I trun the car off trying to start back up is a problem. If it starts it will start back firing idling rough and cut off and after about 45 minutes it will start and run like nothing ever happened. It seem like somthing a sensor is bad but I can't find out which on it is. Will the oxegin sensor or the crank sensor do this?
Find a car repair manual for your Chevy Monte Carlo Repair Question.
Have the computer scanned at a parts store. Most will do it for free and will identify if there is a sensor problem. Also, check the intake / head gaskets for leaks. Finally, does the cooling fan come on when it gets hot? Also, check the coolant level to make sure it's full.
Let me know what you find.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
