Engine Mechanical problem
1996 Chevy Lumina 6 cyl Two Wheel Drive Automatic 120000 miles
I have a 1996 Chevy Lumina Mini Van that will not start. I just replaced the fuel filter. I can hear the fuel pump cycle when you turn the key but the van will not start. Just before the van stopped running it was sputtering like it was not getting fuel. I thought it might be a plugged filter but it still will not run. What may be the cause of this as it is not running and like I said you can hear the pump cycle and there was fuel in the filter when I took the old 1 off. It will run for a moment with quick start sprayed into the throttle body but will not stay running. Any help would be greatly appreciated. Thank-you Erick
