Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1998 Chevy Cheyenne Tru...
Auto Repair1993 Lincoln Continental...
Auto Repair1993 Chevy Suburban Slo...
Auto Repair1997 Chevy Blazer 1997 ...
Auto Repair2002 Saturn Sc2 Alternator
Auto Repair2002 Honda Accord Check...
Auto Repair1995 Bmw 740 Windshield...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1996 Chevy Express Engine Stalling and hesitating
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Mon Jul 28, 2008 11:13 am
By Blue34, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
1996 Chevy Express V8 Two Wheel Drive Automatic 120K miles
I purchased the Van a year ago and right of the bat the Fuel pump went out. Had a new GM fuel pump installed. Went on a 2000 mile trip up to Colorado and back with a full load. No issue on the way up, but on the way back during the drive the engine hesitated while we where going down the Freeway @ 65 mph, but never stalled. When we finally made it back into Phoenix we hit some stop and go traffic and once again we were in the fast lane doing 50 mph when the engine shutoff. It started right back up and I made it home, but the engine was acting as if it wasn't getting fuel. The engine check light never came on, I am assuming that no codes would be present. I noticed when I backed it into the grauge it smelt like their was a gas leak or the engine was running rich. I checked the tail pipe and it smelt like a very strong fuel oder. I also checked for leaks and a clogged air filter, and I found no leaks and the air filter was fine. I thought maybe the O2 sensors were acting up, not sure how to check and also some friends mentioned the charcol canister check valve and maybe a fuel injector stuck open. Any ideas on what to check?
Find a car repair manual for your Chevy Express Repair Question.
Posted at Mon Jul 28, 2008 5:45 pm
By dennyp, Moderator
Reputation: 119.9Reputation: 119.9Reputation: 119.9Reputation: 119.9Reputation: 119.9Reputation: 119.9 (120) Give Feedback | Votes: 5
First, have it scanned for any trouble codes. It would also be a good idea to check the fuel pressure with the engime off and with the engine running. If possible, drive the vehicle with a fuel pressure gauge connected. This will help you see what is going on when it acts up.
Posted at Tue Jul 29, 2008 9:40 pm
I verified that no trouble codes were present on computer. I measured the fuel pressure with the ignition on I get 60 psi. With the engine running I get 52 psi. I drove it around with the pressure gauge hooked on and I see fluctuation between 52 and 60 psi, seem to move around the most when I accelrated. I am assuming this is normal. My repair manual doesn't show the correct opperating pressure for the fuel injection systems. The van also didn't hesitate or stall. I did all this at night when the out side temperature is under 100 degrees. The van seems to start having problems when the outside temperature gets over 100 degrees, I plan on checking tomorrow as well. Are their any sensors that would start to give false signals due to extreme outside temp?
Posted at Wed Jul 30, 2008 9:17 am
Fuel psi spec. 60-66psi.
Posted at Thu Jul 31, 2008 7:49 pm
Does this mean that the fuel pressure should be between 60-66 psi when the engine is running or when the ignition is on without the engine running? It seems to hold pressure after I shut the ignition off, so I don't think their is a leak. Would you recommend changing the fuel pump or are their other causes?
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
