Welcome to our question and answer forum were over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Transmission problem
1996 Chevy Cavalier 4 cyl Two Wheel Drive Manual
My 1996 Chevy Cavilier Z24 manual will start but it will not go into gear. I check the clutch fulid and it was empty so i filled it up. i pumped the clutch then check again it was no longer full so i put more in and pumped it a little more. then i left and came back about an hour later and all of the dot 3 fluid was leaking out of the bottom of the engine. What needs to be done
Find a
repair manual for your Chevy Cavalier Repair Question.
Posted at Wed May 14, 2008 7:11 pm
By
Advertisment,
Find a
If the fluid is leaking at the engine end of the system, you will have a faulty slave Cylinder, this will have to be replaced and the hydraulic system re bleed of air.
Mark (mhpautos)
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
